Old 8-Sep-2015, 10:36 PM   #3
lippertt
Originally Posted by Jake V View Post
1. Do you know the model number of the antenna? If not, can you post a good picture?
this is circa 2000, it cost quite a bit, I'm thinking it's good quality, it's missing tubes on the flat section from various ice storms, I've uploaded a pic.
2. Are you aiming about 279 degrees as measured by a real compass (just a bit north of Detroit / Windsor)?
As best as I can, if my phones compass is correct it's slightly north of west
3. You mentioned the antenna is older. Is the coax and connections also older? Even if the antenna is in perfect condition the connections and coax can weather and degrade the signal. Your signals are mostly two edge and on the weaker side. You're going to need a powerful antenna and maybe an amplifier (especially if driving several televisions).
They looked surprisingly good to me when I scaled it, not rusted, just weathered
4. You didn't mention it, but is your antenna on the roof? Are there large obstructions towards the west (big buildings, mountains, etc.)?
10 ft above the peak. no large obstructions, definitely trees and windmills in the path however thanks
