Old 8-Sep-2015, 10:22 PM   #4
DennisC
Thanks for responding rabbit73. I can answer some of your questions now but have to get to an appointment and will follow up later. Here is my new report after I measured and got 25’ to bottom edge of lower antenna. http://www.tvfool.com/?option=com_wr...8e03367320af70 Actually I am about 1/8 mile north of the Walmart and 1/8 mile West of Goat Milk Stuff in Scottsburg. I am in a subdivision with only a few trees, I have a tree close to the antenna on the East side but not blocking the aim I don’t think, no thick tree growth South of the antenna for at least 1/8 to ΒΌ mile. I will need to get on top of the house to check but I am sure I connected the 2 antennas with a combiner not a splitter. My knowledge of this topic is not at all technical so I am unsure exactly what a UVSJ is. Is there a simple way for me to determine if the U8000 is modified to make it bi-directional as I had the antennas installed by a local electrician about 4 years ago and I simply do not know. Can I attach a photo and if so would this be helpful? The CPA19 did bring in the PBS stations but for some reason WAVE channel 3 was always a problem. Now with Juice pre amp WAVE 3 is great and PBS is very poor or no signal. There are no other buildings close by other than private homes. The wind over time may have rotated the antennas if that is possible? I don’t know the exact direction the antennas are aimed until I get on the roof to check although they are generally South and a few degrees to the West I think. Hopefully this can help some.
DennisC is offline   Reply With Quote
