Old 8-Sep-2015, 7:03 PM   #3
One local PBS station WKPC PBS KET (channel 15 or 17 from Louisville, KY) will work some of the time but not at all dependable. During a channel search the TV locates the WKPC station with 3 of it’s 6 sub channels only.
I only see a main and two sub channels, but PBS is known to change the lineup.
http://www.rabbitears.info/market.ph...&callsign=wkpc
WCLJ Ind 42 and WKMJ PBS 68 are local Louisville stations that I am unable to pick up during a TV channel scan.
You are on the fringe of coverage for WCLJ:
And there is a peak in the signal path:
The results are similar for WKMJ.
