Old 8-Sep-2015, 6:26 PM   #2
Hi, Dennis:
Please redo your tvfool report at your antenna height using exact coordinates of the antenna. Your present report is at 10 ft. I tried doing a report at 30 ft using an estimated location near Walmart Supercenter and Goat Milk Stuff in Scottsburg, and the report looked a lot better.
I see a lot of trees in your area. Are there trees or other buildings in the signal paths?
Is the Juice getting the same channels as the CPA19, or is there a difference?
Which way are the antennas aimed?
Are you combining the two antennas with a UVSJ or a splitter in reverse?
Is your U8000 still modified to make it bi-directional by removing or rotating the reflector rods, as mentioned in your previous thread? If you disable the reflector, you are making the antenna bi-directional, but you have lost some of the gain that you had in its original forward direction.
