Old 8-Sep-2015, 6:27 PM   #2
Jake V
1. Do you know the model number of the antenna? If not, can you post a good picture?
2. Are you aiming about 279 degrees as measured by a real compass (just a bit north of Detroit / Windsor)?
3. You mentioned the antenna is older. Is the coax and connections also older? Even if the antenna is in perfect condition the connections and coax can weather and degrade the signal. Your signals are mostly two edge and on the weaker side. You're going to need a powerful antenna and maybe an amplifier (especially if driving several televisions).
4. You didn't mention it, but is your antenna on the roof? Are there large obstructions towards the west (big buildings, mountains, etc.)?
