Old 8-Sep-2015, 2:22 PM   #21
rickbb
Originally Posted by Irata View Post
I talked to the lady across the street with the antenna tower(not pictured). It's a bit shorter but only installed a few years back. Said it was never used and told me I could have it if I could get it removed safely.
You should jump on that, or put up a gable end mast pole mounting system with 15 to 20 feet of mast and guy wires on your roof. Add a "real" antenna and you may be surprised at what you can pick up.
Your improvements with just moving it up higher indicates to me that it's worth the trouble to go for it.
