I would give the attic a try, but keep the fingers crossed tightly, especially for channel 13. Unfortunately their highly directional signal is pointed away from you, so even outside it would be trciky at 72 miles out.
If the attic doesn't work is the wife flexible on an outside antenna?
The other thing to consider is if you get the Winegard 7698 it is nearly impossible to re-fold w/o damage. I would lean towards the Antennacraft HBU 55 if you can find one on Ebay.
