Old 14-Jan-2011, 9:32 PM   #21
tfrook
Originally Posted by No static at all View Post
I would try
1. Raising/lowering the antenna 6-12 inches at it's present location.
2. Walk the roof to find a better spot if no improvement above.
3. Add a Winegard 8700 pre-amp if no improvement above.
4. Replace the ANT-751 with a Winegard 7694 if all else fails.
You are right on the edge of what the ANT-751 can do on it's own from my experience. The 7694 is about 10-20% stronger.
The crazy thing is that after hooking up my HDHR I can view and record channel 18 (cw) perfectly on the pc. I wonder if its a tuner issue on the pdp5060.
tfrook is offline   Reply With Quote
