Old 8-Sep-2015, 12:28 AM   #14
olnick
I got the 600B up and running! (new batteries!)
Now at the entry into the house with only the RCA TVPRAMP1R feeding the Sadelco meter these are the latest results:
Ch Db
2 -31
3 -29
4 -32
5 -30
6 -27
7 -15 to >-35 db
9 +1
11 -18
18 -30
19 -30
20 -28
27 -28
33 -30
34 -14
42 -27
57 -30
58 -30
59 -30
60 -18
61 -22
Is there anything else I should be checking?? The DB readings were NOT steady and changed 2,3,4 DB per reading?
Would it be worth my effort to get up on the roof and check the readings without the TVPRAMP1R in place to see what the antenna is doing on its own? I did manage to get additional ch's after I installed the TVPRAMP1R.
I do appreciate all the help in pointing me in the correct direction....
Thanks
Olnick
olnick is offline   Reply With Quote
