Old 6-Sep-2015, 7:11 PM   #2
Welcome, cd1515:
It's not a dumb question.
You can use some of the equipment, but not all. Remove the dish and put an RCA ANT751 antenna in its place aimed at 97 degrees magnetic by a pocket compass. Use just one of the coax lines that goes to the apartment. Remove all dish splitters and multi switches; do not use them.
The dish guy should have grounded the coax in some way using a grounding block. You should try to use that for you coax downlead.
Todd Humphrey doesn't speak for the NFPA that publishes the NEC code, but he has some ideas that are helpful. The local electrical inspector has the final say if you are willing to get him involved. Some inspectors are more friendly than others; a local electrician could tell you.
