Old 6-Sep-2015, 2:34 PM   #19
Thanks for the photos.
I also added a preamp I found at Menards and removed the Amazon amp.
What preamp did you get? Is it near the antenna or down at the lower end of the coax?
Doing a check with the Tivo I still got all the Louisville except one AND the displayed signal strength went from 55-60 to 70 or above.
As of 10:19 tonight, WRTV, WTHR, WFYI, WNDY, WTTK, WHMB, and WXIN from Indy all coming in solid.
That sounds like a big improvement to me.
My plan is still to move it to the top of the but if I put the original short J pole on there will the roof affect reception from the north?
I'm not sure which way is north after looking at the photos. Which direction does the side of the house in the third photo face? Without knowing that, my answer is if the present location isn't affected, then the planned location will not be affected.
On a side note, some of my neighbors have old OTA antennas on 30-40 foot towers that have probably been there since the 70's. I'm a bit jealous.
Ah, yes: I see towers in photo 2.
