Old 14-Jan-2011, 6:12 PM   #1
afbbb
Choosing the Correct Attic Antenna
Hey all,
I've been lurking here for a little while. I've been without ANY TV for about 4 months now - I don't miss it TOO much! But I'm to the point where I'd like to get the major networks...
Here is my report - http://www.tvfool.com/?option=com_wr...3cf41051f666ca
The house is a single story, with a standard gabled roof. The surrounding terrain is flat with no obstructions between the signal and me. I would prefer to pull in the Chicago channels that are listed at 311*, I don't care at all about the stronger local signals (channels 24, 17, and 49).
I'm currently renting the house, so I can't install anything on the roof. I put the elevation at 15' on my report. I would like to choose an antenna that I can stick up in the attic (plenty of room up there) and run some RG6 straight to my TV (only 1 set). I'm probably going to be adding a Home Theater PC in the near future, so I don't know if that will influence any of the hardware setup.
I hope that I can get this to work! Thanks in advance for your help...
Eric
afbbb is offline   Reply With Quote
