Old 3-Sep-2015, 12:57 AM   #3
Hi, Vic:
Tim is right. If you are lucky, if you can get your antenna high enough, and if there are no trees or buildings in the signal paths, you might get PBS, Fox, and ABC; CBS and NBC would be even more difficult.
You would need a Winegard HD7698P antenna and a Channel Master 7777 preamp.
The consumer rotators aren't too reliable with big antennas. You should consider a ham rotator.
consumer grade:
http://www.solidsignal.com/pview.asp?p=cm9521a
Your TV should be able to add a channel after a scan or you will need to rescan after a change of direction.
