I originally went with the RCA distribution amp because I read multiple times in the forums that was the best way to go. I also explained I did not have good results with the RCA Pre-Amp and was very happy with the results of the Distribution Amp.
My in house setup. I have an HDHomrun tuner with 2 coax connecters directly into the distribution amp. I have an HDHomerun Plus with 1 coax connecter directly into the distribution amp. And instead of capping the 4 coax connecter on the distribution amp. I ran a cable with a splitter supplying 2 televisions. 1 32" tv in my bedroom and 1 60" television in my living room. Out of caution, I will disconnect the coax from my 60" television when thunderstorms are predicted in the area.
