Old 1-Sep-2015, 10:51 AM   #3
Tower Guy, GroundRMast, and I all identified the problem and the needed solution in your thread regarding WFSB. If you have done nothing in that regard, then go do it.
WFSB and WCBS are on the same channel and are short-spaced and you are in the middle. You cannot use a bi-directional antenna and expect it to work without issues.
