Thread: Antenna options
Old 31-Aug-2015, 8:42 PM   #39
sl1982
Ok i will test that out. London is on the back side of the antenna and I dont even pick it up. The one from Oil springs i do pick up but not with 100% signal quality as it is pretty off axis from where I have the antennas pointed. I would prefer to keep the db8e amplified as it does help a few problematic channels come in reliably. If i remember correctly i did have only the c5 hooked up at one points just to the amp but not though the combiner. Does that make a difference?
sl1982 is offline   Reply With Quote
