Old 31-Aug-2015, 3:18 PM   #14
Yes I'm grounded with a block approximately 8 to 10 feet away from the antenna.
Good.
That means the interference is more serious than I thought and is also coming in other ways. We will be hearing more reports like yours.
Besides unplugging, the aluminum foil and ferrite core solutions seem to work in some cases. The foil probably makes the stick temperature rise too high because it can't dissipate heat as well.
