Thanks for the suggestions. The orange tag simply says that if the wire becomes loose or if i need to move the wire to contact them.
So when you say i can scrape some of the black insulation off the wire, do you mean about where the orange tag is?
Or if i wanted to add a washer between the two i could just add the washer on top of the current setup and with the new ground underneath it? Im pretty sure another washer would fit on top of the current bolt
Don't worry, not holding you to any of this. Just looking at my options
Thanks
