Thread: Antenna options
Old 30-Aug-2015, 6:49 PM   #34
The link to your image doesn't work.
I found a local antenna shop and they suggested getting a preamp.
What preamp did you get?
On another note, channel 45 which is in the same area as channel 7 comes in at 98% signal quality.
WDIV NBC is on real channel 45 which comes in on the DB8E; WJBK Fox on real channel 7 comes in on the C5.
How is your system hooked up; what is connected to what?
The problem is the signal quality on that channel is only around 50% and it cuts in and out.
What are you using to measure signal quality, the HDHR for Signal Quality (SNR) and Symbol Quality (Inverse of Errors)?
