Old 30-Aug-2015, 5:42 PM   #1
Old Town
Help with Antenna Options
Hello,
I'm new to the forums and just got rid of DirecTV. I have cabling throughout the house that I was hoping to take advantage of by adding an antenna to the existing coax and sending the signal throughout the house to three different locations. Is this possible?
My house is in Alexandria VA, just south of Washington DC. The front of the house faces nearly due West, and just slightly towards the North. Their are some 2 story apartment buildings across the street probably 100' away.
I'm interested in placing the antenna in the front of the house, inside a window on the 2nd floor (Approximately 12' to 15' above ground level).
I should have good reception to many of the DC stations. Here's the tvfool report: http://www.tvfool.com/?option=com_wr...8e036a20413224
I am interested if anyone can lend some advice on what type of antenna would work best for this application, and if there are any specific products you would recommend. I'm not looking to break the bank, but as I'm saving $75 a month after ditching the dish, I'm willing to consider options. To make things more complicated the antenna would be visible from the street, so something that is discreet would be preferable.
Last, I could also consider placing an antenna in the attic, but this would require some additional wiring and not ideal.
Thanks in advance for your help.
Old Town is offline   Reply With Quote
