I am resurrecting this thread. I finally got around to replacing the antenna (now a winegard hd7694p), installed a new mast (higher now), re-pointed the antenna to 267 degrees and away from the pines that I thought could be the issue, tried two separate cable runs. Argghh! I am stilling have an issue. A bit better but a millisecond audio drop every 5 minutes or so. I have also tried separate runs to the TV as I thought that could be the issue.
Oh what to do now? Could I have a bad internal TV tuner? Seems like that would not be it. Should I try to amplify to signal? This run is 50 feet max to the TV. Could this be some type of atmospheric aberration? Could it be the hodgepodge of wires I have behind my receiver / some type of electrical interference from the receiver? It is a big receiver (HK AVR 254) that is very close to the antenna cables? Very frustrating.
