Old 29-Aug-2015, 12:34 AM   #7
I have the antenna pointed 142 deg (south to Boston)
Boston is 162 degrees magnetic.
What antenna are you using?
Do either of your TVs have a signal strength indicator to find out how weak a signal can be and still be received? Do you still have the Sadelco meter?
http://www.nitehawk.com/k6jey/MiniMaxManual.pdf
I agree with ADTech; something isn't right if you need both amps.
Where do you have the gain control set on the Winegard DA-1036 distribution amp?
http://starkelectronic.com/win1036.htm
WHDH NBC, virtual channel 7.1, real channel 42 is your weakest channel in the series. If you are getting it on the upstairs set, you should be getting the same channels as on the downstairs set.
