Just about any small UHF/high VHF combo antenna should work. Our ClearStream 2V would be my recommendation. No amp is needed unless you're going to supply the whole neighborhood with signal.
Existing coax, as long as it is not longer used for anything else, works great. That means that your cable-provided internet or VOIP service must be completely segregated from your antenna signals. NO EXCEPTIONS.
