Old 28-Aug-2015, 3:01 PM   #3
rickbb
What did the living room get without the pre-amp?
If you are barely getting enough signal with the pre-amp it is possible that 35 feet of cable could be losing enough, or introducing enough noise to drop channels. Check the cable you added, make sure isn't damaged or have a bad connection.
If you switch the TV's does the problem stay in the bedroom or move with that TV? Could be that it just has a crappy tuner.
If it is the bedroom run and the line and connections check out ok maybe the distribution amp would be better than the splitter.
