Old 28-Aug-2015, 1:06 AM   #2
Jake V
It is quite possible that the splitter gives your bedroom television sufficient power on only 4 channels. Please post your TV Fool report so that we can see if you have enough signal to drive two televisions without an amplifier.
First, I'd check all your connections to the bedroom television.
Then I'd probably try your Winegard DA-1036 distribution amp since you already have it.
Or, I'd probably cry the bedroom television down to the living room and connect it there. If it gets 24 channels then you know that there is signal loss getting to the bedroom television.
