Old 26-Aug-2015, 6:37 PM   #12
That sounds like too many wires under the same screw. You might need an Intersystem Bonding Terminal Block/Bar (IBTB):
https://www.google.com/?gws_rd=ssl#q...nding+terminal
https://www.erico.com/catalog/literature/E803S-NAEN.pdf
http://www.erico.com/category.asp?category=R2431
https://www.erico.com/catalog/literature/E828B-NAEN.pdf
When you are adding other wires to the house electrical system ground, it is important not to disconnect the house electrical system from its own ground connection, even for a moment, for safety reasons. You should use a split bolt to add another wire to an existing wire that is grounded. It is also why the IBTB has a "lay in" feature for the house ground wire, so that it isn't necessary to disconnect it from its ground.
From my personal experience, using a grounding block to ground the coax shield is the most important thing to do. It will protect you from leakage current shocks from AC operated equipment.
CECB Leakage Current
Getting A/C voltage on converter box's antenna input !
http://www.digitalhome.ca/forum/81-o...ml#post1457594
Equipment Leakage Current
http://www.digitalhome.ca/forum/81-o...ml#post1457668
Do you know that there is a grounding thread on the Canadian forum?
