Old 26-Aug-2015, 3:01 PM   #9
Darken
Ok I guess I wasnt visualizing it correctly. So a "separate ground wire' would mean 2 ground wires? If i have a coax/messenger ground wouldn't that ground both the tripod and the coax to the grounding block? So my coax/messenger ground needs to be secured to the tripod and run to the grounding block to be grounded through the electrical box BUT i also need a separate ground just for the tripod? Is this where i could fasten another ground from the tripod to a nearby grounding rod? Or i suppose i could also just run the 2nd ground the same route as the original one to the grounding block? Is this correct?
Thanks again for helping me make sense of this
Darken is offline   Reply With Quote
