Old 25-Aug-2015, 3:13 PM   #4
Darken
Thanks for the replies.
So if I understand correctly, i would be better off putting the grounding block closer to where i want the coax to enter the house and then extend a grounding wire approx 30 feet to the electrical box (main ground) as opposed to having the grounding block next to the electrical box and extending the coax 30 feet to where it enters the house? The real issue unfortunately is that the antenna is on the east end of the house, the electrical box is right in the middle and the coax will need to enter on the west end because that is where the living room is. So either the coax or the ground wire will need to be extended after the ground block, just trying to figure out which one is best.
Darken is offline   Reply With Quote
