Old 25-Aug-2015, 2:27 PM   #3
rickbb
Generally speaking;
Put the coax grounding block nearest to where it will enter your house. You can then run a bare copper or aluminum ground wire from the block over to your service ground.
This keeps the coax short for good signal and completes the grounding path.
BUT, you really should check with your local building/electrical codes. They can be very different from place to place.
