Old 13-Jan-2011, 6:18 PM   #3
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
GroundUrMast is absolutely on the right track with his recommendations. I would only add that you should get as much altitude as is practical with your antenna system.
His choice of a rotator is an excellent, albeit expensive one. if you need to economize, you can use a Channel Master 9521a as a less-expensive alternative, however, it is nowhere nearly as good a rotator as the Hy-Gain AR-40
