Old 24-Aug-2015, 7:07 PM   #1
tally
City Outdoor Antenna Help - Omni-directional?
Please refer to the attached signal analysis report:
http://www.tvfool.com/?option=com_wr...8e03423e972845
As you can see, channels are relatively close by but with blocks of channels 180 degrees of one another. Also, there is a pole I can clamp on to on the NE side of the house about 15-20 feet high, which would be the easiest mounting location without going to the roof.
1) Please suggest an antenna.
2) Do I need to go with an omni-directional antenna? I want to avoid a rotating antenna.
3) Do I need to mount it on the roof (I would prefer not to if I can) but then will the house block out too much signal strength on the SW located channels.
Thanks for the input!
tally is offline   Reply With Quote
