Old 13-Jan-2011, 6:07 PM   #2
I would not choose that particular antenna. I am suspicious of the advertising claims.
Based on the information in the report you provided, I would say you should consider the installation of a tower, 60' high if possible. You are located a fair distance from most of the broadcast towers and hills block your line of site to most. I realize that a tower is not possible for everyone, still, every bit of altitude you can get is precious in your situation.
I would choose an Antennas Direct 91-XG and an Antennacraft Y-10713. Both antennas are large deep fringe antennas. To get the best use from those antennas I would use a heavy duty rotator such as a Hy-Gain AR-40. A preamplifier such as the Channel Master CM7777 has inputs for the separate UHF and VHF antennas.
I realize that I'm suggesting one of the more expensive solutions, but I am rather certain that you will get little satisfaction spending money on the antenna you refer to.
