Old 20-Aug-2015, 3:21 PM   #9
rickbb
Originally Posted by lostagg View Post
Thanks everyone. I came home and tried tweaking things a little further and I now have channels 8.1, 8.2, 10.1, 10.2, 15.1, and 39.1(only on one TV). Do I stand a chance of getting anymore channels with the mentioned setups? Thanks again for all the feedback and suggestions.
You won't really know until you try. I will second Tower Guys recommendation for a 4 bay bowtie though, they have worked really well for me.
I think with a 4bay with the reflector removed and mounted as high as you can get and aimed at 57 degrees you should get more channels.
But I think your bigger problem is your channels are all 2edge, you are down behind several hills putting you in their shadow from the towers. Which is why the higher you can get the antenna the better, (usually that is, exceptions abound).
