Old 19-Aug-2015, 12:09 AM   #3
lostagg
What stations are you trying to get?
Fox, PBS, NBC and any other not Spanish channels.
What direction is the antenna aimed?
It's roughly at 221 degrees. I'm not sure I understand the "two edged" reference.
I will try at 146 when I get home and see what happens. I'm not opposed to a different antenna. Should I look into this as well?
Below is the antenna at 20 ft. What do you think?
http://www.tvfool.com/?option=com_wr...8e03f93c996fb5
lostagg is offline   Reply With Quote
