What stations are you trying to get?
What direction is the antenna aimed?
If you're not interested in the stations at 166 degrees (mostly in Spanish?) you'd probably do best by aiming at 146 degrees for the major networks (Fox, PBS, NBC). The stations at 221 degrees (CBS and ABC) are strong and might be picked up.
The downside is that all your stations are two edged.
You might re-run your TV Fool plot at a higher elevation and consider getting the antenna higher than 10 feet.
