Thanks Rabbit, I will read/study through that thread again to see If there's any ideas I can implement for myself. I know my antenna configuration is not 100% set in stone as of yet, there's many things I can try to tweak it a bit better.
For what it's worth, the Tivo Roamio is incapable at present of showing Corrected RS errors at any time, so that field will ALWAYS be 0.
That's what I have gathered after a search on Google from various sites. Perhaps Tivo company will put out a revised firmware sometime that will fix this issue, but I'm not holding my breath.
My problem (when it happens) also is seen on my tv set tuner hooked right next to my Tivo, so it's an inherent antenna reception issue, NOT just a Tivo issue. Not withstanding the fact of course that the Tivo has a built-in 4 way splitter and 4 tuners, which of course would explain signal % level differences between Tivo and tv set.
