Old 13-Aug-2015, 12:25 AM   #6
The strongest TV signal is WNLO with a Noise Margin of 73.2 dB, which puts it in the overload category. To that you can add ~10 dB of antenna gain which brings you up to a NM of 83.2 dB.
Going on the basis of Signal Power dBm in the report, WNLO is -17.6 dBm, and adding 10 dB antenna gain gives -7.6 dBm.
ATSC Recommended Practice:
5.1 Sensitivity
5.2 Multi-Signal Overload
You can see why an attenuator might be necessary.
I will advise him to place the antenna on a tripod on his roof. I have grounded my antenna in the past, so I will make sure that the tripod/mast and the coax run will be grounded before entering the house.
Good, that will reduce the chance of strong TV and FM signals from causing interference. They can get directly into the TV set if the coax isn't grounded with a grounding block.
