I'd try a DB-4, but remove the reflector before you install it. It will give you a bidirectional pattern. Aim the antenna for Toronto and Colden. The Grand Island stations will just come it slightly misaimed. If you don't have enough signal after a 4 way splitter get a Channel Master 3414 distribution amplifier. If you want WBBZ on channel 7 you'll need a VHF antenna plus a UVSJ.
