Old 8-Aug-2015, 1:53 AM   #13
Originally Posted by Greenish Apple View Post
ADTech, would a Antenna's Direct DB8e pointed at 220° magnetic be a good choice?
There's nothing at 220° to pick up.
The OP should still get CFTO and maybe CHCH & Global?
-GA-
CFTO - Depends on the trees and whether or not the antenna is aimed at that station.
CHCH - Easily, unless the trees kill it before it gets to the antenna.
CIII (Global) - Probably. VHF reception on the UHF antennas often peaks at weird angles. I have not examined the DB8e on VHF 7 since I don't have any channel 7 stations within range of anywhere I've tested.
