Old 6-Aug-2015, 10:19 PM   #6
Kaptkimbo
tv reception Middleville, MI area
Every thing is new since lightning strike including TV... the mast and ground are the only things remaining....I agree I should be pulling in stations left and right....just trying to determine what is wrong...would a kink in the coaxial cable severely limit the signal? when I put in the new cable I think i may have kinked in pulling through the walls..it seemed OK and have had reception through it till the last 10 days. The cable after the power inserter runs out to a grounding block then another section to the up to the pre-amp then pre-amp to antenna.
When I first installed it I had a splitter (since removed) that had a short run to my daughter TV and she received 20 plus channels. I could see if my multimeter will measure any resistance on the cable run
Kaptkimbo is offline   Reply With Quote
