Old 6-Aug-2015, 1:19 PM   #5
Maury Markowitz
If you combine two identical antennas not aimed in the same direction, the same signals will interfere with each other when they reach the combining point if they are not in phase.
This is what I thought, and it is not covered on HDTVPrimer - or if it is, it is hidden in the discussion of combiners.
In this case, two antennas in different directions, is it not the case that if one of them is 90 degrees off the other, the phasing issue will be eliminated because the output from the second will be zero?
But I still have the combiner loss too, right? And is that loss 3 db?
What are you getting now by callsign and real channel number?
What would you consider great, that you aren't getting now?
http://www.tvfool.com/?option=com_wr...8e0347474ce022
I'm currently getting lots of channels, including many that the system says are 2edge. On the chart at the link above, I most everything up to WKBW, the exceptions being WUTV and CHEX analog (poor image, no sound, don't care. 9, in high VHF, is in and out.
And that's pretty good, but it will start fading when it gets cooler. By the end of October most of the Buffalo stations will be marginal or gone, and 9 will be barely usable.
So, I'd like to fix the fading, and ideally add ION to my list.
Maury Markowitz is offline   Reply With Quote
