Originally Posted by tony2tall
Would you also recommend using a Channel Master 1110 VHF?
Sure, the CM 1110 is a BIG antenna that will work, but it is no longer in production.
It is listed to receive at longer distances than the Winegard HD5030
Just FYI, mileage ratings on antennas are somewhat arbitrary (mostly driven by marketing) and could be way off. Real situations will vary with terrain, buildings, trees, and other factors that are unique to each setup. Mileage ratings should not be used to compare antennas.
What really matters is the net gain of the antenna, which is a directly measurable quantity (or can be derived from detailed computer models).
