Old 28-Jul-2015, 3:05 PM   #9
Thanks for the report.
I do still receive wwto even with the attenuation.
You don't need to eliminate it completely, just weaken it a lot. How much attenuation did you use and with what attenuators?
Is this the setup you used?
C4 > UVSJ > UVSJ > attenuator > LNA-200 > coax > power inserter > TV
I found out I don't even need an antenna to pull in wwto. I had the cable disconnected and the signal still came through perfectly, I thought that was a little strange.
That's not strange, it's normal. If the coax is not connected to the TV, then the TV tuner isn't grounded, and WWTO can get directly into the TV cabinet.
In order to keep the very strong WWTO from interfering with the reception of your weak signals the coax must be grounded with a grounding block that is connected to the house electrical system ground, and the coax must be connected to the TV. In other words, there must be a continuous shield from the antenna all the way down to the TV.
Do you think a large yagi style antenna might pull in the signal better?
It might make the weak 2Edge signals from 62 degrees magnetic a little stronger, but it might also make WWTO a little stronger.
You not only need to make the weak signals stronger, you also need to make WWTO weaker to reduce the difference between the two.
WWTO is in the opposite direction from your weak desired signals. If a yagi had a better front-to-back ratio than the C4, it would help.
for UHF only, but will pick up strong VHF
https://www.antennasdirect.com/cmss_...-sellsheet.pdf
https://www.antennasdirect.com/store...V-Antenna.html
https://www.antennasdirect.com/cmss_...y/91XG-TDS.pdf
for UHF and VHF
http://www.winegard.com/kbase/uploads/HD7698P.pdf
If you substituted an Antennas Direct Juice preamp, which is highly resistant to overload and has a metal case, for the LNA-200 preamp, it might tolerate WWTO better.
It is possible to order a special filter to make WWTO a lot weaker without making your weak signals too weak from its insertion loss, but if the two UVSJs don't make it weak enough during the test with the coax grounded, I doubt that the custom filter would do any better.
If WWTO still gets into the TV with the coax grounded, the only thing left to try is exotic measures like the TV in a screened enclosure (Faraday Cage) that is grounded, with a small viewing opening in the front. The antenna coming in the rear with an F-81 feed thru adapter, and the AC power coming thru with a chassis RF filter. If the viewing opening still lets in too much WWTO, you could insert a piece of low-E glass which would block interference from WWTO but let you see the TV screen.
Extreme measures are sometimes necessary, even if your equipment is operating properly, if you have very strong EMI.
John Stanley, K4ERO, was able to operate a ham station when he was living at the transmitter site of HCJB in Quito, Ecuador. A 40 meter dipole collected enough RF to light a 100 watt bulb. See Front-End Overload, A Worst Case Example on p214 of The ARRL Antenna Compendium, Vol. 3.
This is where the quad loop antenna was invented (patent no. 2,537,191) by Clarence C. Moore, W9LZX, because of problems with corona discharges from the previous four-element antennas that were fed by high power transmitters located at 10,000 feet altitude in the Andes. The aluminum elements got so hot that pieces melted and fell to ground.
Quad antenna - Wikipedia, the free encyclopedia
http://www.digitalhome.ca/forum/186-...ml#post1307146
Did you aim the C4 at 62 degrees magnetic for the test?
Was the coax grounded to the house electrical system ground with a grounding block for the test?
Before I suggest a different antenna with more gain and maybe better front-to-back ratio, a different preamp that is more resistant to overload, or a special filter, I want to be sure about your test setup.
