I have installed the USJVs. The quality improved slightly but during the day the signal is still pretty low. I do still receive wwto even with the attenuation. I found out I don't even need an antenna to pull in wwto. I had the cable disconnected and the signal still came through perfectly, I thought that was a little strange. Do you think a large yagi style antenna might pull in the signal better?
