Old 20-Jul-2015, 3:40 AM   #1
MarcCharette
Recommendations for pointing a DB8e
I am moving my antenna into my attic due to concerns over the stability of my roof mounted mast (had some pretty bad wind the other day and it was swaying pretty bad)
Here is my report: http://www.tvfool.com/?option=com_wr...8e033e2fa4e3a1
These are the channels I care about:
CKCO-DT
CIII-DT
CICO-DT
CITY-DT
CITS-DT
CHCH-DT
I had previously tried to get CHCJ-DT but gave up due to it not being reliable (I found a way to stream it online anyway)
So to my question: I have an Antennas Direct DB8e that I've already put in the attic. Seeing as I have signals coming from multiple directions I figured that was a good one to get because it allows you to point it in two different directions. So what would you suggest is the best way to point it so that the weaker channels like CITY-DT aren't overpowered by CIII-DT?
You may wonder why I don't just do trial and error until a get what I want, but it's very difficult to get in the attic and also very hot and unpleasant to be in there so I want to make sure I'm pointing it with a plan in place so I can get out quickly.
Thanks!
MarcCharette is offline   Reply With Quote
