Old 19-Jul-2015, 2:26 AM   #20
uvsj looks like this.
That looks correct.
Before changing system to one preamp, try removing CH 8 yagi from your original two preamp system as proposed. Don't change more than one thing at the same time.
So if Chan 7 works I might need to get tinlee to build ac7 injector?
Maybe so. I want to be as sure as possible your chances are good because an AC7 is expensive. Their engineer can help you decide.
WCIQ PBS on real channel 7 is much weaker than your strongest signals, and it is a poor quality 2Edge signal because of terrain interference, making it difficult to receive. It also has co-channel interference from WMUM also on channel 7, which is weak enough to probably not be a threat. It also has adjacent channel interference from CH 8.
