Will this work?
Please tell me if my idea can work: I am now looking at making this an easy attic mount by doing the following: running the coax from the antenna to the only upstairs coax hookup, taking a splitter off the antenna and running it into the
upstairs hookup, making it connect to the whole house system by running it into the FRONT of the upstairs wall plate. Then, drilling a second hole in the wall plate, attaching a female to female fitting, and then running the second coax from the antenna and splitter into the BACK of the wall plate, so a TV can be hooked up here. This seems to me like it should work. But what say ye?
Thanks again for the help. I am trying to do this without splicing into the house cable. Since it is a condo I am not finding where the cable feed enters my unit.
Reason: Sentence structure
