Old 14-Jul-2015, 11:38 PM   #2
Jake V
Nice plot.
If it were mine I'd probably use a RCA ANT-751 or an Antennas Direct C2-V pointed to about 150 degrees on a compass. Most of your channels are at 169 degrees, but you have a few at 142 degrees and 142 degrees. Adjust as necessary. No amp needed. You CBS at 321 degrees is strong so it should be picked up. Make sure you mount the antenna LOS to the SE and NW.
