Since Antennacraft antennas are now hard to find now that they are out of business I'd recommend using the Winegard 7697p. That combined with a rotor should give you every channel to at least WFSB and possibly a couple below that on your TV Fool report.
Use a good quality RG 6 cable to help reduce signals loss. If you find you need a pre amp try the RCA TVPRAMP1R. I use this in an area with stronger signals than yours and I can easily obtain a couple of Yellow signals on my TV Fool report with it and not have to worry about overloading the TV tuner.
