Old 14-Jul-2015, 8:40 PM   #1
deeciple
New to antenna. Need advice on best config.
Hi All,
I recently cut the cable and picked up the following antenna:
http://www.walmart.com/ip/RCA-Suburb...-Mast/10828410
Here is a link to my tvfool report:
http://www.tvfool.com/?option=com_wr...8e03d9fde6536e
Based on the report I pointed my antenna at 355 degrees. It is about 15 feet above the ground on the north facing side of the house and I have an 8 way splitter/amp boosting the signal by 3.5 db.
I am happy with the reception I am getting (I get about 25 channels and between 60% to 90% signal quality with most channels being 80% and above) but I want to be sure I am getting the best I can.
I am new to this and would like to know if there is anything I can do to improve the number of channels I am getting. Only caveat is I can't go any higher with the antenna but I am open to exchanging it for a different one that may work better.
Thanks for any advice you can offer.
Ken
deeciple is offline   Reply With Quote
